Hey guys ive been building this long travel sandrail and finally got it up and running this summer and im trying to work the bugs out. This thing is a monster..1st gear would wheelie strait up in the air, 2nd would pull it back up and to the same, then 3rd with alittle bounce i could ride it out at like a 45%.. anyways it was down for a month or so while i made some changes and finished up somethings on it. The maf was unplug because i had relocated it and the BPV was capped off. We hooked up the BPV and i started working on calibrating the maf and i just couldnt get it right so i ended up putting the original tune i had back in and its just never had the same power i couldnt even get it to wheelie even after unhookin the maf and capping off the BPV like it was originally.
So ive spent the last week or so reading up on tuning these things figured i start at the begining and work my way up i got the maf almost dialed in and was working my way though it and my computer does and update and somehow i couldnt read the maf. i finally got that maf hist working but a few mins before it will read anything but 0s. still a work in progess il have everything pretty close to 0s and then next time i look at it there all over the place
Anyways it still seems down on power so i was thinking maybe i hurt it or have a boost leak as my boost histo still only shows like 16-17lbs. when from my understanding it should be 22-25 with DAL cranked up to 325 and WG at 95% soo for shits and giggles i drop the WG down to 65% and put the DALs back down where they were and to my shock the thing seems to be making more power and starts to wheelie again sooo im confused i do a handful of short logs playing with the wg in just the 100% load column from 65 to 80 to 85 and still only can get 18lbs.. what im i missing??
