Hi guys
Well I thought I had the SD tune done. Today I was running errands and about 30 minutes in I shut it off for about 2 minutes. It had been running great.
I started it up and it idled at 1300 RPM with no throttle response. My WB was off the charts lean. I didn't have my laptop with me so I was planning on having my son bring to me. While I was on the phone I tried starting it again and this time it responded normally. I drove it around for about an hour with no problems.
This evening it had sat for about 2 hours and I wanted to bring it into the shop. It started up fine and ran fine. I shut it off in the shop, then realized I needed to move it back a few feet.
It started the then a 1300 RPM idle with absolutely no throttle response. (Drive-by-wire)
I know if I flash an older tune into it, it will run.
I've attached the tune I've been running, the scan log of me driving it around today, and a short scan log of it running with no throttle response.
I sure could use some help here, it has me stumped.
EDIT: Sure enough after I posted this it started and runs fine. I can't trust this now.
