Working on this for a friend. Thought it would be a good learning process. its n/a with a cobra jet and a single blade whipple. i have what i believe is the correct T-body data. it drives pretty good but needs alittle work. the first issue im encountering is the t-blade wont close past 2 deg so its pulling lots of timing to try and get to commanded idle. what should i look to do first
