Results 1 to 3 of 3
Thread: Saturn Redline / Pontiac GXP Torque Converter Stall Speed? 5L40E
    Searched everywhere, but can't seem to find the stock automatic Redline/GXP stall RPM.
    Working with Bluecat Trans table and need the number. Minimum RPM would be handy too! : )
    Thanks!
    13,565
    Maybe someone will know the number off hand but you could maybe give these guys a call. This place makes factory stall converters for the aftermarket, a place called Triple Edge Performance builds tons of transmissions for the GM FWD 3800 community and he stands by these new stock stall converters when he sells them with transmissions.
    http://www.gopnh.com/Automotive-Part...4&submit=Enter
    Just an option anyway.
    Thanks for the link!
    Emailed them and was told 1800-2000 rpm stall and "Minimum Lockup RPM that is a spec that we don’t know because that is determined by when it is commanded by the computer based on gear, speed, engine rpms, etc."
