Results 1 to 11 of 11
Thread: C7 A6 Callaway Supercharger Speed limiter issue
    Sep 2011
    Germany
    196
    Hi,
    we have a C7 A6 with Callaway Supercharger in our shop and the cusromer complains the car running to a Speed Limit at 187mph.
    in the scanner i can see Torque Source Trans S limiting but i cant find any table to remove the limiter.
    HP Tuners Support was looking to the file and told me its a Tuning issue.
    thanks for help.
    Sep 2011
    Germany
    196
    any ideas?
    Tuning Addict
    6,780
    Speed limiter minimum is where I would start then make sure you have good tires...
    ~Greg Huggins~
    Sep 2011
    Germany
    196
    no difference if i set speed limiter minimum to 249mph.
    Got a log?
    And after looking at the trans table I will say that I bet it is hitting the rev limiter in 5th gear.
    Sep 2011
    Germany
    196
    have to send the log monday cause im not on the PC.
    i cant find gear rev Limit at the trans. what table ID do you mean?
    Mar 2010
    Texas Hill Country
    3,299
    Quote Originally Posted by zr1driver View Post
    I think he means your shift points are calibrated incorrectly so its not shifting.
    Apr 2007
    1,104
    quick and dirty way is to change the conditions to 8k.
    93 Ranger. 5.3 D1X. 1069hp.
    Does not matter..... A6 will not shift to 6th gear under WOT. Only way to go faster is with a taller tire or higher rev limit or change the ring/pinion.
    Apr 2007
    1,104
    look at your auto shift speed tables. .
