Results 1 to 9 of 9
Thread: 2017 Camaro SS - MAP reading at idle
    May 2007
    489
    Can anyone connect to a 2016, 2017 or 2018 Camaro SS and tell me what their MAP reading is at idle. Trying to rule out a bad MAP on my car. Mine was showing 42kpa, so on some advise I pulled the intake off and checked the seals, all were good. I put the intake back down and torqued it to spec. I am now getting 34kpa at idle, but the code is still showing up in the ECM log.
    Thanks in advance... Todd
    Advanced Tuner veee8's Avatar
    Apr 2006
    Raleigh, NC
    449
    You should have approximately 100 kpa at key on engine off at sea level. Does it just stay stuck at 34 or does it move around? What mods? I've seen map sensor extension harnesses get plugged in upside down from Whipple and cause something like this.
    www.crawford-racing.com
    Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
    May 2007
    489
    It moves around, I am getting around 32-35 kpa at idle with 1.34 to 1.37 volts at idle on the MAP sensor. I keep getting a P129D code showing up that is tripping my check engine light.
    2017 Camaro SS w/ 1LE package
    Ported stock intake manifold and throttle body
    Roto-fab CAI
    ARH headers with no cats
    Stock NPP muffler system
    Mar 2010
    Texas Hill Country
    3,299
    He's asking what it reads at Key On, Engine Off rather than at idle.
    May 2007
    489
    I will check here in a bit. Never checked or logged them at key on engine off.
    May 2003
    South FL
    1,369
    Did you clear the code in HP Scanner afterwards? Or did you disconnect the negative battery cable? I know some sensors will throw codes if they are disconnected when there is power to the system. Just trying to clarify if this code is re-occurring even after cleared.
    Did you change and MAP based Airflow tables?
    [email protected]
    Owner/GM Calibrator
    May 2007
    489
    98kpa at key on engine off.
    I have tried to clear the codes with the HPT scanner, no lucky. I even just tried to pull the battery for over 15 minutes. Then as as soon as the car was back on I scanned for codes and the P129d showed as "pending, permanent". As soon as I scanned it again the code showed up as permanent.
    Going to have the dealer try and clear it with their system after work today.
    Apr 2006
    Raleigh, NC
    449
    That is about right for a map reading at idle with the stock cam and key on engine off. If the check engine light is not on in the dash, those codes will eventually disappear from the permanent status in the scanner after so many key cycles with no problem found. It is just the way HPT reports the DTC's now.
    May 2007
    489
    ok, thank helps me feel a little better at least. I am guessing that from my improper install of the intake tripped the code. The tuner thinks it may be the new tune, but several other people dont see it in their tunes.
