Strategy for load scaling
Hey guys, I wanted to see what sorta strategies people do to scale their load. Both MBT and borderline knock!
I went and scaled from 0.2 to 2.4 in .2 increments which means the down low the load doesn't have as much clarity as a standard tune. I have since seen tuners scale both the rpm and the load values but only the last value to put a linear max/min timing value to progress towards.
I don't yet know the impact of either method but i assume the higher clarity down low helps with fuel efficiency and the higher clarity up high helps fine tune timing higher up the rev and load range.
What do you guys do and do you see any benefits of the approach?
I rescaled mine evenly up to 2.2 but I guess either approach would work with modifying the top load value being the easiest option.
