Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
Thread: Fuel Cut Torque Ratio Questions
  1. #21
    Quote Originally Posted by CCS86 View Post
    Hi Steven, thank you for the explanation!
    Yet again, this seems to conflict with LaSota's explanation of the table (Fuel Cut Torque Ratio). He first tells you to change just the Driver Demand entry from 0.95 to 1, and you are done.
    Then, 40 pages later, he comes back to the same table and says to zero out every single entry. Citing that "0=no torque reduction, and 1=100% torque reduction".
    It sounds like you disagree entirely with this view. Would you recommend leaving this table alone, making slight modifications, or zeroing it out?
    Even the description in Editor doesn't seem to match your description:
    The Editor description appears to have been messed up when it was moved, and ended up a mix of a correct and incorrect description.
    Regardless, my description above still holds true.
    A certain amount of reduction is allowed via spark, it will use spark to reduce that amount, and then it'll further reduce it via fuel enleanment and then fuel cut as needed.
    You're not going to disable the reduction short of disabling the torque module itself, merely affect how the reduction is achieved.
    I'll reupdate these descriptions.
    As to how to tune the tables, that's up to you. Zeroing all the fuel cut tables will just say to use fuel enleanment before fuel cut if possible, but it'll be minor as very little torque can be reduced via enleanment. It wont disable fuel cut as a method for reducing torque.
    I will say this:
    I find too many tuners concentrate on increasing power via trying to sabotage any system that reduces torque, instead of properly allowing the engine to make more torque as needed by increasing torque demands. Work with the torque system and you'll have the benefits of torque control when needed (like during traction control, idle control, etc) vs working against it and trying to tune it like its from the 60s
    If its not broke, just give it time.
  2. #22
    Senior Tuner CCS86's Avatar
    Nov 2017
    Austin
    1,089
    Thanks Steven.
    I'm with you on trying to work with the systems. Correct the reason a system is intervening, rather than disable the whole system.
  3. #23
    Senior Tuner metroplex's Avatar
    Apr 2013
    Detroit, MI
    1,077
    I'm currently experiencing massive spark reduction during WOT shifting. The spark advance can be 24* advance prior to the shift, and then be reduced to -3* during the shift, dragging it out 0.5-0.8 seconds total and it feels like hitting a wall or massive trans slippage when this occurs (but I can tell from engine and input/output shaft RPM it is not slipping). I do not see fuel injector pulsewidth or pump flow being reduced at this point, just spark. The torque source is always "Trans Shift Mod". The controller is TC-1791 and the trans is a 6F55, and the engine is the N/A 3.5L V6
    On the TC-1797 with EcoBoost V6 engines and the same 6F55, this spark cut does not occur and I don't even see Trans Shift Mod as the torque source during a WOT shift. So the engine is making almost twice the torque as the N/A 3.5 but isn't getting the spark cut.
    Any ideas if this is related to the spark cut ratio table? Shift Modulation 0 or 1 doesn't have an effect. Raising/Maxing the Trans Tq Mgmt has no effect either.
  4. #24
    Nov 2017
    Austin
    1,089
    Quote Originally Posted by Steven@HPTuners View Post
    @Steven, it has been over 4 years and the description still reads the same in the latest beta version. Can you please correct the descriptions in Editor?
  5. #25
    Still the same.
  6. #26
    Advanced Tuner silverbullet08's Avatar
    Dec 2009
    Houston, TX
    453
    I'm interested in your findings here. I'm having the exact same logged symptoms. There appears to be a load limit threshold for the spark cut to occur. If I turn the boost down the car will cut ignition during shift and turning boost up ignition cut goes away giving it this "soggy" shift feel. Tq ratios and sources log the same with boost up or down so seems to be load or accel rate related.
    Raising Spark only ratio value "shift modulation" from 0 to any value creates a violent fuel cut and enleanment when "shift mod" source is commanded even at PT and WOT.
    When looking at the tune what the ratio authorities are allowed, I am confused as to what tells it to use enleanment vs cut when it will use enleanment occasionally or cut with the same reduction ratio but at different loads.
    HP-Unlimited Tuning and Custom Fabrication
    Houston area performance parts dealer
    MD800 Mustang Dyno 713-560-3889 Taylor
    2016 Camaro A8 "shop car" FIRST 6th GEN CAMARO OVER 200mph IN THE MILE 203.5mph
  7. #27
    Baltimore, Md
    1,208
    LOL they are not always interested in fixing screw ups for the most part. If its not adding a new vehicle then good luck...
    Real fun is mislabled lockup torque converter stuff when UNLOCK makes it LOCK. Super cool LOL
    Factory Stock 97 SS M6 13.51 @ 104.3 mph
    Stock Longblock LS1 w/ 233/238 P.S.I. Cam
    10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
    '99 TA trunk mounted 76mm 6 Liter
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    32psi and still winding out 5th on the highway somewhere
  8. #28
    Nov 2017
    Austin
    1,089
    Quote Originally Posted by GrannySShifting View Post
    Exactly my thoughts.
    I have dialed back the amount of tuning I do because they seem to have no interest in actually improving the software. They just want to add new vehicles and sell licenses.
    Even simple requests of mine:
    - When you average a signal in Scanner (when creating a math parameter), it should sample points symmetrically (before and after the point in question) in order to avoid the current behavior, which is to time shift the averaged channel.
    Just get sidelined for years now.
    Here is what averaging does to that signal: avg.gif
    Such a simple fix for a meaningful issue. HPT doesn't care.
