2007 Corvette C6 Vert. A6
LME LS402, Pat G custom cam, ATI 10% OD Damper
Circle D triple disc 2600, 3.42 Diff
YSI, 3.0 pulley, ID 1000's
Alky Control Meth,
ARH 1 7/8 headers,
1009 RWHP @ 7000, 817 RWT @ 6000
Is your IVT definition scaled correctly - that's if you did the double half trick? Having cold start issues? Usually the tale tale Jody
~Greg Huggins~
Alky Control Meth,
ARH 1 7/8 headers,
What do your iat's and ivt's report? Injector tip temp should be half what your getting - should start out at 100c when hot reflashing / coolant temp when cold starting...
~Greg Huggins~
Wow.... just ignore me... LOL
I just went and looked at the log again, and the injector temp was max 123. Either I just was tired and saw it wrong, or maybe I looked at it with the key off or something ? No idea but I was sure I saw 300s. Anyways, all seems normal now.
Ok...........pretty sure I looked at intake valve temp by mistake........
Alky Control Meth,
ARH 1 7/8 headers,
OK, that sounds more like it
~Greg Huggins~
Factory Stock 97 SS M6 13.51 @ 104.3 mph
Stock Longblock LS1 w/ 233/238 P.S.I. Cam
10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
'99 TA trunk mounted 76mm 6 Liter
9.0s in '09 @ 153 MPH
Turbo 5.3 Volvo 740 Wagon
32psi and still winding out 5th on the highway somewhere
2nd page / 2nd post
~Greg Huggins~
I dont see these kind of injector tip temp swings? Hot restart a couple times 127F is all I see, drop a couple degrees maybe after running? Hood closed, 85 degrees outside
let it sit 5mins off after it's fully hot, do it 3-4 times it should keep climbing or maybe your platform is different. You can also put it in gear (auto) or don't push clutch in (manual) and try to crank it.. this will update the Inj Tip Temp. It does on mine anyway.
The problem comes in when you go to track and turn off car for few minutes in line or after you make a run and stop and shut off for a few mins. Same on the Dyno if you shut off for few mins for whatever reason. Or, running around shopping, few quick stops is all it takes.
2010 Camaro LS3 (E38 ECU - Spark only). MS3X running complete RTT fuel control (wideband).
Whipple 2.9L, 3.875" Pulley, kit injectors, supplied MSD Boost-A-Pump, stock pump
LG Motorsports 1 7/8" Headers - No Cats, stock mid pipe with JBA Axle Back
ZL1 Wheels/Tires
Not as noticeable with scaled injectors or stock engines. Let it get to temp. Reflash hot, then restart and see how much fuel trims change.
~Greg Huggins~
So GHuggins, I should tune my MAF for the trims I want, then reflash hot and see what happens to the trims?
All of your offsets are negative in first post? Yet the plot shows positive values and higher than the table? Trying to follow this and start tuning my airflow tomorrow in the proper order.
One of those views I posted was showing the difference after the table was tuned in - which is why it showed negative values...
I tune pretty much like this - yours is a stock CTSV with some light mods - right? Put everything back to stock / Put in correct injector data / Fire - put in 100% MAF - dial in MAF and VE at the same time ( I use the cylinder math formula for VE - [2320.71]*(273.15+[50011.241])*1000*15/([50070.56]*[50030.91]) ) Then by the time your MAF is dialed in really close, your VE should be within 5%... Wait until injector tip temp is around 55 or 60 C to start logging - after MAF and VE are really close - dial in injector tip temp using Scott's formula on page 2 or trims - formula is quicker... With yours being a CTSV - leave IVT table alone... Once injector tip temp is dialed in start making the rest of the corrections to your VE and MAF using safe ignition timing granted... Then when it's within 1 to 2 % move onto spark and idle issues... I also suggest dialing in your O2's while dialing in your MAF and VE the first time around - easy to use st's 0ed area and see whether or not your lambda or air fuel errors are staying within 1% at the same time while the rpms are being held up...
~Greg Huggins~
I meant the ivt open loop fueling adjustment table... Should have clarified I guess...
~Greg Huggins~
No, but it's been modified, so go back to stock on that one...
~Greg Huggins~
