can someone give me the values to put in LM programmer, analog 1 and analog 2... please
Black Pontiac Trans Am WS.7- Runs on E85
And soon to be powered by Twin Turbos.
How to run your LS1 on E85
I personally like to set my wideband to be a range of 0volts = 10 AFR and 5volts = 18 AFR
then I set up a custom EIO PID to be Volts/0.625 + 10
that is what I use on the wideband side of things
-Scott -
And what about the NB side?
I havent been using the Narrowband side...
I couldnt tell you as I havent looked at it in a long time..LOL
-Scott -
I TO ASKED HOW TO MAKE THE NARROWBAND side of th LC1 to work and dont understand
2000 Firebird,2002 O.S.,LQ4 370,Borg Warner S475,truck mani.,Eagle crank,Callies Compstar Rods,Wiseco-11 4.030 pistons 9.4:1 comp.,LS3CNC heads,LS3 intake,NW92mm throttle body,ID1000 injectors,BTR trunion upgrade,LJMS STG3 cam,LS7 Lifters,ARP Studs-bolts,Frozen Boost A to W intercooler,JGS 60MM BOV,2 40mmJGS Wastegates,4L80E trans wth segment swap,CircleD 3400 single disk,MOSER 12 3.31gears ,BMR K-Mem.,2 Walboro 450 pumps,Returnstyle fuelsystem MAGNAFUEL regulator.
LS1Tech sig KRAZY K 2000 TA
Is this the right way to set up the PID for LC-1?Originally Posted by soundengineer
no....Originally Posted by Runn WS7
you need 0.625 not 6.25
0.625
and sensor should be AFR
-Scott -
haha... just got out of bed...Originally Posted by soundengineer
It was the sensor i was thinking about. Great thanks. Now lets try it out
