Results 1 to 20 of 20
Thread: 2017+ 10R80 transmission OSS to RPM Excel sheet converter
    First of all, I would like to thank TOYOGURU for his submission in this thread https://www.hptuners.com/forum/showt...ift-map-tuning
    I do not want to take the credit for this as he started it and his sheet has helped me previously in tuning my 6R80 truck before.
    Now, the sheet attached is for the newer 10 speed transmission aka 10R80. I have adjusted it to have what it needs to convert the OSS to Actual RPM with various tabs within.
    The base concept is to have it suite my 2017 Raptor. I do believe the rest of the 10R80 (Ford Based) can accommodate this too.
    There are 6 tabs to choose from :
    • Up Shift
    • Down Shift
    • Traction Control Up Shift in lb.ft
    • Traction Control Up Shift in Nm
    • TCC Slip
    • TCC UnLock
    How to use it:
    1. Copy the OSS values from the chosen tab from your tune
    2. Paste in the OSS area within the sheet
    3. Adjust the OSS values to your liking (Increasing or Decreasing)
    4. Initial values and later adjustments will show the actual RPM within the table at the right
    5. When with adjustments, Copy the values from the OSS table within the excel sheet
    6. Paste the values in the designated table within the tune file
    10R80 rpm and TCC Converter (reverse rpm calc).xlsx
    Please, feel free to let me know of any adjustments needed. I have tested this and have had the results needed.
    Jun 2006
    Rham, NC
    155
    The spreadsheet looks really good..haven't had a chance to do a compare vs what the new ecoboost tables are yet but believe Ill be using this in the near future for the mustang.
    You get all of the credit, my spreadsheet merely gave you an idea, you did all the work on this one and expanded on it, looks really nice!
    Current toy- 97 SCSB OBS chevy forged 6.0/4l80 combo with a bit of boost..currently back under the knife
    To many previous vehicles to list
    Quote Originally Posted by toyoguru View Post
    Thank You Sir
    Oct 2016
    Poland
    1,737
    Great work but there are some bugs in your sheet, L27 for example changes both AE27 but also Z27. I used your sheet to tune a 2018 and noticed this right away.
    Corrected
    10R80 rpm and TCC Converter.xlsx
    Please let me know of anything else.
    Tuner in Training brandong007's Avatar
    Nov 2012
    North Mississippi
    16
    Lightbulb 10R80 transmission RPM to OSS reverse calculation Excel sheet converter
    Very nice...I updated the spreadsheet a bit and added inverse calculations of OSS->RPM. The new tabs allow you to input what RPM you want shift to be at and then the OSS is calculated from that rather than playing with the OSS numbers to get the expected outcome for RPM. Whatcha think?
    2007 NNBS Silverado LTZ Crew Cab Z71 VortecMAX (L76) / Stock Everything / Airaid M.I.T using stock box / 93 octane tuned by me 22*-25* timing / 0-60 mph 6.8 sec - Coming Soon: Longtubes, exaust, vette servo
    2004 GMC Canyon Crew Cab Z71 4WD / swapped 5.3 / Beefed up 4L60e / 2800 stall / dual 2.5" exhaust / 24" Magnaflow / 93 Octane tuned by me /w Wideband 25*-28* timing - SOLD!
    Quote Originally Posted by brandong007 View Post
    I think its much better and easier your way. It should help others too.
    Thanks for the update
    Advanced Tuner small tuner's Avatar
    Nov 2015
    271
    any one have sheet like this for 6R80 (same spread sheet) not only shift point rpm
    Oct 2019
    Interesting
    Quote Originally Posted by mrshanab View Post
    I have a 2018 mustang GT with a10R80 that I had Modified with SCT tune. I have been getting DTC P061A and P061B (Torque Mis match) during full throttle (or close) acceleration. The vehicle goes into limp mode and can be reset with the programmer. At first the acceleration is ok but then there seems to be a hard shift or two and then goes into limp mode.
    I?m wondering if with the performance tue there is an unexpected change in torque that results in a mismatch from the transmission. Do you have any thoughts on if a tune for the TX is necessary in addition?
    tried using this but im getting ### symbols and no numbers is this locked in a way or am I doing something wrong. thanks let me know
    Quote Originally Posted by Eduardoc22 View Post
    Try now please
    attachment has been updated
    Try now please
    Still getting same result
    Can you send a screen shut?
    not letting me
    Sep 2016
    391
    That just means the number does not fit in the cell space, go into the column where that happens and double click on the edges
    Jun 2020
    Alabama
    5
    I?m having this very same issue with my 10r80, not wanting to come out of gear and up-shift to the next gear. Then limp mode for a second.
    Any help please?
    Jun 2020
    Alabama
    5
    Quote Originally Posted by PG Bullitt View Post
    Have you found a answer to your question?
    Sep 2006
    Arizona
    600
    Quote Originally Posted by Nitmer View Post
    Any help please?
    Is your shiftpoint set higher than your max RPM? You typically want to set your max rpm HIGHER than the actual rpm you want to shift at.
    Nov 2019
    6
    Hi All, I updated the Excel file with a conversion to MPH. I am used to tuning GM vehicles so it is easier for me to see MPH with dealing with the shift mapping/TCC/etc. Hope it helps others as well.10R80 rpm and TCC Converter (reverse rpm calc and MPH).xlsx
    do we need to have the tire circ mm target or not ?
    i ran a 27.6 tire on a daily basis, but 28 or 26 at drag strip
    thanks !
