Results 1 to 7 of 7
Thread: 2016 Z06 Throttle
    Mar 2014
    231
    2016 Z06 Throttle
    Have a friend with a 2016 Z06 and he wants to if there is something he can do about the throttle hanging. I've never driven the car so I can only go by his description. He says that when he lets off the throttle that the rpm's hang for about a second before dropping as if the throttle blade isn't closing. Is there something that can be changed in the tune to eliminate this?
    I can post the tune if necessary but it's completely stock at the moment.
    Thanks!
    Nov 2009
    All Around
    3,149
    trans?
    Mar 2014
    231
    A8. Thanks
    Mar 2014
    231
    I guess nobody else has run into this slow to respond pedal issue?
    Mar 2010
    Texas Hill Country
    3,299
    pretty common observation with no publicized fix
    Mar 2014
    231
    Ah okay. If it was my personal car, I would do some testing with the tune but that takes time and lots of patience and most people want immediate results.
    Thanks!
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    The Driver Demand settings can be adjusted to help with the throttle lagging. The logic behind the Gen5 DGI motors are similar to the newer Fords. The only problem is with an A8 if I remember clearly is the axis is set up via VSS instead of RPM so a little trial and error to get it where it wants to act should work.
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
