Results 1 to 9 of 9
Thread: 2017 Sierra 5.3 , E92A, Cut-off ?!
    May 2013
    8
    i'm trying to enter a rpm cut-off on a 2017 Sierra
    i tried everything , no cut off at all
    i appreciate ur help
    Oct 2014
    Alfred, Maine
    19
    Do you mean a "rev limiter"?
    Jan 2008
    10
    post your tune
    Oct 2014
    Alfred, Maine
    19
    are you trying to make your 17 bounce of the rev limiter like a gen 3?
    Potential Tuner racetronik's Avatar
    Jun 2017
    5
    Ok i have asked HP tuners for the IMMEDIATE TORQUE TYPE and they said its no longer available. Since on OLDER trucks upto 2016 is set on PLEASABLE, i have done the following:
    Go to SPARK >>> ADVANCE and in MINIMUM FINAL SPARK where your vehicle is on REV LIMIT start with 5 DEGREES and it should give you the rev limiter. Please note that this is not the right way cause in any case your TIMING will never go below 5. 10 DEGREES will make it faster.
    You need to still set the other parameters like Switch OVER DELAY etc to make it WORK and I have tested on 2017 GMC and is working ok like 1500 5.3 Sierra/Silverado.
    TEST ON YOUR OWN RISK !!!
    Sep 2015
    3
    Its possible post your tune will go from there
    Aug 2017
    17
    In the Cutoff/ DFCO tab it will show your rev limiter in there. Keep in mind, if you are looking to get more revs out of it you will have to raise your WOT shift speeds in the trans section as well. I did this on my 17 Silverado.
    May 2013
    8
    problem solved
    Fuel=cutoff==down left
    cmd Torque Delta + Commanded Torque
    what i did
    i set all the tables with the high value was there
    not the maximum value for the table
    May 2023
    19
    About the switch over delay etc what a good number to run ?
    And what also I should change could you post your file please ?
