Results 1 to 2 of 2
Thread: Garmin Virb Ultra 30
    Sep 2017
    4
    Has anyone used this camera with Track Addict yet? Is it possible to directly use the GPS that's in the Virb? I figured since it's a 10hz GPS it would provide more accurate data than using the built in phone GPS (usually 1hz). I was going to consider buying a 10hz GPS, ODBII add on and a Go Pro but if the Virb can take the place of the Go Pro and GPS device I could just buy that and only need to add on the OBD II device.
    HPT Employee Weston@HPTuners's Avatar
    Jul 2014
    39.735034, -103.894459
    868
    Unfortunately, we aren't able to stream live GPS data from any GPS-enabled camera at this time. A camera's GPS data can often be used with RaceRender afterward, but TrackAddict is designed around live data feeds, so you'd need one of the compatible GPS add-on devices to get enhanced GPS data into it.
