Results 1 to 2 of 2
Thread: 2010 camaro ss 6l80 incorrect 1 2 upshift at wot
    Sep 2017
    Hi. The wifes Camaro wont 1 2 upshift at 6200 rpm like I programmed it to. the 2 3 and 3 4 shifts are working properly. Am I missing something?
    Check to make sure the ECU is actually commanding the 2nd gear shift, because if it is not. Make sure that your shift MPH setting also matches or is below the actual speed of the vehicle when it's at the RPM level where you need it to shift, but looking at the logs.
