Results 1 to 10 of 10
Thread: VZ E38 ECU Unlinked after Flash
    Oct 2008
    Perth Australia
    161
    VZ Commodore L76 6L Auto has decided to unlink all modules after a Write Calibration of minor changes on existing running tune.
    Half way through writing tune, all the engine bay relays started clicking madly and continue to do so when ignition is on.
    Car wont start no obviously and tried 2 other known good ECUs and all still the same.
    Tried relinking with various TECH 2 style scanners and its still the same .
    What gives ?
    Jan 2014
    Australia
    1,982
    may not help your current situation but i always flash with only the accessories on which should work in the VZ also, just saves it going thru all the dash/abs/ect errors every time
    Oct 2008
    Perth Australia
    161
    Ah i always thought ignition had to be on ?
    Jan 2014
    Australia
    1,982
    yea some have to but if the ecu is powered up by acc then it will be fine, in my VE i always just have acc on or in the earlier days i had the ign on but found it works in acc, im pretty sure the VZ will work in acc also
    Oct 2008
    Perth Australia
    161
    It will connect and write tune and connect to scanner and clear codes on accs but soon as ignition is turned on the relays click and it wont connect, go back to accs and it has all the codes there again
    Oct 2008
    Perth Australia
    161
    Anyone ?
    Jan 2014
    Australia
    1,982
    are u losing power or something with ign on checked all fuses ?
    Oct 2008
    Perth Australia
    161
    Yeh, checked fuses and earths
    Tuning Addict
    Jan 2015
    6,802
    With relays doing what they're doing - sounds like voltage issue - especially if you've tried another known good ecu... Have you tried a "good" jump box? AND by good I mean one decently sized and amperage capable... Last thing would be to try a write entire if it's honestly a corrupt calibration losing it's vin or something like that...
    ~Greg Huggins~
    Oct 2008
    Perth Australia
    161
    Put my jump pack on it soon as i heard relays going because i thought it was the battery. The car drove to me running fine. Will try a a different battery just in case.
