Id assume with the DI stuff theres only so much window of time to complete an injection cycle as you cant on the back of an intake valve like we are used to. There should be a rough formula I would think that would take into account rpm (as speed goes up window would have to decrease) and also start of injection timing... The later you start the shorter the window would get, the earlier the longer up to a point. Not sure if higher rpm events would want a later or earlier injection timing for max power as a general
