Originally Posted by
Phil'sC5Vette
So Ive been R&Ding on my first 5.0 Mustang. A little confusing from the GM side with all the mapping points, but I started to get a good understanding of them after a couple hours. Though difficult to understand what influences each map setting. in WOT, most of the time I retrieved my data from say map 21 or 22, but sometime after I because changing the IVT, Id collect data from MP 25. Im ok with the above.
I have the car running well, but sometimes when going from hard throttle in a high manual gear, then pushing it to neutral to coast, the Mustang would stall. 70% of the time it would not do it, but it sucked when It did.
When the mustang would stall, I looked at the MPs, and thought if I changed just those values back to stock, it would help, but it did not. Then I said since it uses above 20 MP at WOT, let me change all the MP below 20 back to stock and see if that helps. I don't think it did.
Another question other than help me with the stalling issue, Ive commanded .847 Lambda during WOT in the tune and it hits that mark in the scan, but im my scanner its telling me im commanding .90 Lambda not .847. is there a table im missing to change that influences what the computer thinks my commanded it ?
Also I noticed in my commanded the temperature for fueling only goes up to 16 degrees. Can/should that be "renormalize" to a higher engine temperature. I think im running about 190 degrees at normal operating and WOT temps.
Attached is the arrival tune which we believe is the stock tune and one of the tunes and the scan which monitored the tune.
Phil
