2015 GMC 1500 slt.
Would there be a parameter to adjust for this truck's remote start time? I have pro HPT but I've only used it for my LS1 car.
2015 GMC 1500 slt.
I have not seen a way to edit this yet, maybe someone else has.
I thought I read once that it's something in the BCM that controls this. The only way is to use it, let it run for 10min but press the button again before than 10min mark to extend it another 10min.
Have you tried this?
[ECM] 2135 - Startup Idle Time
I am very interested in this also. I have a remote key fob. The door locks work but the remote start never has. The dealerships tell me the ECU is not set up for it? It is my understanding if the door locks work so should the remote start.
Do you mean how long it cranks before it starts, or how long it will run after starting with remote start?
300 seconds is only 5 minutes. If it was the parameter in question it would be 600 seconds. And the limit is 1 restart that I've read.
In regards to yours not working the doors must be locked for it to enable remote start, try that?
how long it will run, hopefully I never have to mess with the crank duration.
Yes, that is just a shot of mine at 300 sec.
No still won't start. I read it may be in a Body Control Module?
If your truck came with remote start fobs, then it should work. You most likely have dtc stored causing it to not work.
~Greg Huggins~
Ah, the plot thickens. It did not come with the fob. I "negotiated" with the dealer at purchase. It had no fob and just one key. I said I wanted the remote locks capability or, no deal. He said OK and that it had to be programed for it (the fob). I only mentioned remote locks. I didn't say anything about remote start. Looks like my bad.The remote start has never worked. The locks work fine. Is there a Body Control Module reference? It seems like I have the ability to adjust remote start. I think I have seen in the posts here however, just because we have the "screen" doesn't necessarily mean the ECU has it. I have read in other publications the GMC trucks all used the same ECU and ECU capability,unlike the Chevy's. In other word's Denali down to fleet truck, same ECU. I do not know if that is true. I did read it in a reputable periodical. If that's the case the remote start "on" switch might be elsewhere.
I should move this to a new thread.
https://www.hptuners.com/forum/showt...e-start-ON-OFF
