First off, I have opened a service ticket (##99222) and have been patiently awaiting help from tech support.
But...since I am stuck in 3rd gear, and have a 37 mile commute with 30 stop lights, and my car is the only one I have, I need to reach out to all the knowledgeable folks on this forum to see if I can get resolution as soon as humanly possible.
Tech support has been timely, but after today's commute, I'm about done.
The car: 426 Hemi @13:1 compression running 93 octane pump gas
Enhanced Transmissions built tranny
MTCM (custom programmed in 2010 by previous owner Mike Hess)
previously tuned using DS handheld
previously had 3.06 Getrag
Last weekend, I swapped in a 2016 Hellcat rear cradle with 2.62 gears....I know I know...2.62 gears??? I have to run these for a bit before swapping in a 3.09 out of my wife's Scat Charger.
I've read through all 72 pages in the Dodge engine tuning section and all the pages in the Dodge transmission tuning section ahead of doing my swap so I could be aware of what potential problems may arise. I did all the mechanical work in my driveway on ramps and it took me a day and a half. The computer stuff is what I'm not strong on.
Having read as much as I could, I followed the steps to changing the gear ratios (have version 3.6 HPT VCM Suite installed) and it seemed straight forward enough. Did the Init EGS5x after changing gear ratio to 2.62 and entering my tire size.....but I'm stuck in 3rd.
I've emailed all pertinent files to tech support, but I think they're real busy as the communications are there, but not as fast as I would like...so say we all right? lol
I am new to HPT but have owned since early this year and have been reading everything I can, even if I don't understand completely.
Attached is my initial read of my car, both ECM & TCM. I'd appreciate any input...but please...you need to pretend I know nothing...'cause I do know nothing...so if you offer tips or things to try...please use simple English :-)
Thank you in advance.
Chuck
