Results 1 to 20 of 39
Thread: GMTech's cam tables
    Aug 2014
    49
    GMTech's cam tables
    Does anyone have the pictures of those cam tables saved anywhere? They aren't being hosted anymore.
    Sep 2007
    471
    I?m pretty sure it?s because he took them down because he was sick of Tuners stealing his work and then using it to make a profit. I could be wrong, but I?m pretty sure that was why.
    Dec 2008
    Nevada
    4,452
    that is the main reason his descriptive posts in general have been removed. Its not just tune files or pictures of tables, it also includes full blown write-ups. if you weren't around when he was heavily active like myself...your definitely going to be short on reading material.
    That's too bad. I enjoyed reading his posts.
    Tuning Addict
    6,798
    I noticed John hasn't been around in about a month or so - has he left? I haven't checked to see if any of his other post were gone or not...
    ~Greg Huggins~
    Dec 2008
    Nevada
    4,452
    Usually Johns reads stuff in spare time. He comes by to say hi and spew some occasional knowledge. I dont know him well enough to know if he is still around, but i would assume hes just around doing other projects. He did post last month on something.
    Sep 2007
    471
    Last I knew he was posting in the V8 section, and doesn?t frequent here too much. He?s always busy as far as I know, but if you have a question, post it directly to him, or send him a PM. He?s always nice and helpful until people starting spewing off at the mouth, and then he doesn?t want to help. Can?t blame him there.
    Apr 2007
    1,104
    He does that lol
    93 Ranger. 5.3 D1X. 1069hp.
    Aug 2014
    49
    Well, this is kind of a bummer. He certainly has plenty out there to read, but it's hard to put into practice when the pictures he's referencing are missing. I totally understand the reasoning though. I'm working through a cold start issue on my LNF where anytime the temps dip below 50f the car wants to stumble and die for several seconds before it catches it's breath and figures it's life out, this is with cat warmup disabled. I'm thinking about reenabling cat warmup since winter is right around the corner.
    Dec 2014
    AZ
    23
    Does it stumble after the idle drops after the ECT has warmed up? I'm new and collecting some tips for doing a few things like disable cat warmup.
    Aug 2014
    49
    No, it stumbles immediately after startup for about 10 seconds. Eventually it figures things out and the idle stabilizes. I've been told that the DAL table can be manipulated down in the idle area to help fix it. I've also been told it can be cam setting issues causing it. There are a lot of factors involved in getting a nice smooth, consistent idle. It only does this when the coolant temp is 50 degrees or below on startup. It started great during the summer when the temps were warmer. Things are cooling down here in Wisconsin.
    Dec 2008
    Nevada
    4,452
    Jaizero you should program the cams into full separation at idle and use the Dal and ignition to smooth the rpm wave in the scanner out. to figure out what idle advance i want to run i use the commanded ignition tool in the scanner and adjust it until its at a desirable position. the dals take a little more work since RTT isnt available for these ecu's.
    Sep 2007
    471
    What about your ECT spark table (I forget the name of it)? Is it adding or pulling timing at that coolant temp and below?
    Aug 2014
    49
    JustinZ54e47-Final-2.hpt
    That table is neither adding nor subtracting timing at that temp. It's set to zero. I've attached my tune to illustrate.
    Aug 2014
    49
    Quote Originally Posted by cobaltssoverbooster View Post
    Not sure what the commanded ignition tool is. I searched around for something with a similar name, but found nothing.
    Aug 2014
    49
    I've attached a short log of the startup where it stumbles a bit. The timing goes negative where the dip in RPM occurs, after it warms up a bit the timing stays positive and smooths out. Why would timing go negative, I'm not commanding negative timing anywhere?
    Sep 2007
    471
    Then it?s just how you have the tables setup. Getting the tables right with cat warmup off is hard. I can?t give you an exact because I can?t see how your tune is setup, and even if I could, unless you tune like me in the idle range, then it could be way different. My best guess is how the tables are setup. Idle is a pain to get right. I have a write up on idle though I think, if you want to read that and see if it helps any.
    Aug 2014
    49
    I?ve read your idle tuning post and tried some of your suggestions. I can?t figure out why the car tries to idle down so fast. The timing goes negative which causes the idle to drop too low. I?ve added timing to the ECT spark table and even bumped up optimum spark but nothing helps. I?m also confused as to why it only happens in cold weather.
    Sep 2007
    471
    Idle is by far the hardest thing to control because it is such a light load and little things affect it. I spent countless hours in day, and days in weeks, and weeks in months, all while bouncing ideas back and forth with a good buddy of mine trying to figure it out. I?ve come up with a few different things that work, but each car is different, and so many things can change it that I usually stick with stock idle (with some minor table changes) on my prior customer cars. It keeps the headach away from them and me when they are frustrated something changed and they are wanting it retuned. I always kept it tuned on mine, but I also tuned daily. Without being local, or seeing what you are doing I can?t offer much more than just keep at it and I?m sure you?ll get it. Good luck.
    Aug 2014
    49
    Quote Originally Posted by MikeM173 View Post
    Roger that.. I'm thinking I'll just head back to the stock warm up tables and reenable cat warmup. I personally don't mind it, I just hate to be so noisy in the morning for my neighbors lol..
