Can the start/stop feature be turned off in hp tuners. I had a customer ask about this. Says its annoying how the car always turns itself off at stops. Any help would be appreciated. Thanks
ASE Advanced Level Master certified Tech with 20+ yrs
If you look on the General engine tab, under Hybrid capability. It should be selected as Start/Stop. If you select Non-Hybrid, that should disable that feature.
Has anyone confirmed that this works. Have a 2014 I'd like to disable.
It does not fully disable it the starte still kicks in while the car is running from take off
