Results 1 to 5 of 5
Thread: Tip-In Retard info needed LNF Kappa
    Can anyone give me some details on how the Tip In Retard map is activated?
    Does it only kick in at WOT stab, regardless of knock sensor reporting knock?
    Or anytime certain conditions are met, acting as a means of preventing possible knock?
    Or kicks in only when knock is detected? Which doesn't make sense to me because that would just be knock retard working as usual, so why a separate table?
    Thanks!
    Apr 2007
    1,104
    predicted air mass changes based upon a lot of factors.
    The most hated, make the most power.
    93 Ranger. 5.3 D1X. 1069hp.
    Thanks Area47! So could I zero the map to determine if tip in knock I'm seeing is from the map (predicted) or knock sensor?
    Apr 2007
    1,104
    zero it and go about your day
    Area47 you are a man of few words, but I like what you are saying. : )
