here is a log of a new eco f150 with the two injectors per cylinder. E85 tested at E70 and pressure and A/F held steady at 12.0 ratio. check out the log. I haven't added any timing but the knock sensor is adding as much as it can.
the f150 has a modified tune similar to a raptor tune. af was rock solid and could even go richer if needed. the last pull is the only one to look at. it was in 6th gear with as much load as we could get. the first couple were with gasoline in there before the E85 got rolling
enjoy.
chris
