Decide it to go turbo on my 15 Silverado, right now its full bolt on with 36 multi disk converter, cam and nitrous. Truck runs good I just want to try a turbo.
I'm going with a boost cam and at least a 76mm turbo kit nothing big and around 10/12 lbs.
Going to tune it in MAF seen people here going SD but that's just to much for me.
What map senor works in this trucks or can I just leave the stock one?
I've read a lot on the fuel system, What is something that I should use or do before going meth, or how much boost can the stock fuel system hold? I'm using meth after fuel max thinking around the 10/12 lbs. I'm starting with low boost just to make sure fuel its good and know where the fuel gives up, this is the first DI I'm doing boost and read that the fuel system its kind of tricky. Now should I just leave the MAF curve alone and take off fuel from the PE so I can make it up with meth?
Would like to go e85 but not to convince since e85 takes more fuel don't want to have trouble making it work.
