I just purchased HPTuners to perform phaser lockouts on these engines. I've done many in the past and sent the computers off for tuning. I've got an expedition that keeps setting codes for timing advance so I just purchased the tuner to avoid sending the PCM off and waiting every time. So I pulled the tune, found the master disable for the VVT system, it is showing disabled. But on a scanner, it's showing that it's trying to phase the camshafts and eventually sets codes P0011 and P0021, timing advance for both banks. Error degrees are 0 on both banks until it tries to phase, then the error calculations start moving around, because it's trying to advance them and knows it's not responding. Anyone ever run into this? I'm not sure what else I can do. It says it's off but apparently it's not...
Thanks,
Scott
