Results 1 to 4 of 4
Thread: Running Lean
    Oct 2017
    Texas
    2
    Running Lean
    I have a 2000 4.8 with a small cam, long tube headers, and cold air intake. I recently pulled my plugs to find that the porcelain is cracked and that the engine is running lean. I'm new to tuning and would really appreciate if someone could help me out! Thanks in advance
    13,559
    Without a wideband you really have no idea if you are running lean or not, get one of those otherwise you are just shooting in the dark.
    You could attempt to dial in the MAF and VE tables with fuel trims but that is only going to work for part throttle, anything WOT will be open loop with zero o2 sensor control and will be going 100% off your airflow tables. So if they are wrong, everything is wrong. This is why a wideband is a must to know what the real time air fuel ratio is.
    Oct 2017
    Texas
    2
    Would I need one or two of them
    Apr 2016
    34
    One
