My car will always pull 10* or so in first gear before the 1-2 shift and has with several different tunes flashed over the past year. Torque management kicks in, and the car just slows down, then finally reaches the shift, pulls more timing for the shift, then picks back up. It also does it before/after in other gears, but not nearly as bad. Attached is a log. On this log I commanded 1-2 shift at 22mph and 5600 to try and avoid the timing pull, but still does. Could it be something in shift inertia, driver demand, virtual torque/Coefficients, etc? Any help is greatly appreciated!
