kicking out of power enrichment @ WOT. tune, layout, and log attached. please help
my friend that's doing my tuning has told me he's had issues w/ PE kicking out @ WOT. i rewrote entire using my stock tune and then copied over the changes and it seemingly fixed the problem. i just made a few adjustments to stoich, VE, & idle and it just did it again.
thanks in advance for the help,
beau
beau.Layout.xml
2000_camaro_jeff_edit.hpt
at2.hpl
Your TPS voltage is probably over 4.9 volts @ WOT. If so, then raise the TPS High Fail in Engine Diagnostics > Airflow.
Russ Kemp
Russ-
thanks for the quick, helpful feedback. upon adding TPS voltage to channels, i did notice peak was over 4.9 volts @ WOT (4.96). i adjusted TPS High Fail as recommended and made another 2-3 pull and it stayed in PE the entire time. this has been somewhat of an intermittent issue so i will continue to monitor, but hopefully this was the fix.
thanks
-beau
at4 tps voltage fault adjusted to 5v.hpl
at3 w tps voltage.hpl
beau1.Layout.xml
