Results 1 to 3 of 3
Thread: 2017 f150 pcm communication need HELP
    Sep 2009
    2
    Hello Thanks for viewing .
    2017 F150 3.5 Did try to eliminate speed limiter, after writing new calibration. PCM went blank
    NO communication all lights on instrument on No start .
    Try to reed out again nops nothing happens no vin wright vin in , after not supported pcm.???
    Did wright to support but did not get any reply till now (10 hours)
    I need advise shod I try to re flash the pcm with IDS to stock or wait to support?
    Anyone hade similar issues?
    Thanks Mike
    can you take the stock file and do a "write entire"
    2002 Camaro SS, Twin S480s
    2006 Corvette C6, Twin Turbo
    1991 GMC Syclone, LS/AWD/AC
    Feb 2006
    South Carolina
    1,525
    Check your battery voltage and be sure it's up. You may want to add a booster box to help keep it high. Also try a battery reset.
    Jaime
