Originally Posted by
Jinx
I'm having knock at low RPM higher load when the TCC is locked. It's right around 2,000 RPM and can happen anywhere in between 60-120 KPA. I've reduced timing in that area all I care to and honestly, I hate the feel anyway. My other truck that's pretty much bone stock does the same thing in the same area. I'm not getting any knock at higher RPM. I think I want to get the TCC to unlock just before the unfavorable conditions that lead the engine to lug.
So, Under: Transmission -> Auto TCC-> Apply/Release Speed, "Normal" and "Cruise" "Release TPS" I've adjusted the 4th gear release % down to 30% all the way up through 72mph. It didn't seem to do anything when I tested it on the way in to work this morning.
How do I get the TCC to release at a specific throttle percentage?
Otherwise, do any of you have any other ideas to offer to fix my problem?
