Results 1 to 10 of 10
Thread: 2015 TVS "Transfer Case Tq. Limit"
    Working on my buddy's 2015 2.3 TVS with a PMAS, Whipple twin 68mm TB, 72mm pulley, Sai Li return system and E70ish. At the track we kept getting "Transfer Case Torque Limit". Now, obviously, this isn't in the torque switches, and it was limiting timing. Car went 10.72@133 on street tires, but couldn't ever get the timing out of it that I wanted.
    He recently switch to 3.31 gears from the stock 3.73, which searching on here has told me could lead to the problem. But my editor only showed "calibration" and "BCM" for the options on gear ratio. I will post the log. If anyone has any ideas on where to start.
    Tyler 10.25.17 pass 1.hpltyler pass 4.hpl
    Update your beta , transfercase tq limit has a switch
    Sep 2010
    872
    This has been added since like last week, update your beta and you will have access to this
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by Dev1360 View Post
    Additionally, gear adjustments should be done using the Scanner Special Functions for 2015+.
    Jaime
    Update, finally had a chance to load and test it. Didn't work. Any other thoughts?
    Aug 2015
    San Antonio, TX
    179
    Did you change gearing and tire size using the editor or scanner? If yes, try put all that back to stock values, I once tried to change tire diameter values, and got the same issue, eventually put it back to stock and problem went away, although my speedo is a little off due to a different tire size
    I put all of that stuff back to stock. It is taking from the BCM for the gearing change. I will double check it when I get back to my laptop and his car.
    Tuning Addict
    Jan 2015
    6,781
    I've looked in a few 15 GT mustang tunes that I have and unless I'm blind, which is possible, I haven't been able to locate the transfer case torque limit switch anywhere? Anyone have a picture showing where this is located?
    ~Greg Huggins~
    Advanced Tuner Witt's Avatar
    Aug 2006
    Pittsburgh, PA
    380
    I think it's this one labeled "gear box limit".
    Tuning Addict
    Jan 2015
    6,781
    OK, so it is the one labeled gear box limit and not transfer case limit Thank You...
    ~Greg Huggins~
