Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Beta Calculators
    Jan 2013
    Hawaii
    2,101
    Beta Calculators
    So I just noticed these under edit after downloading the latest beta. I dont know how long its been available in the beta or if anyone has played with it. Playing around with some small changes I get some interesting results. May help make things easier for people working on these tables. I'm surprised I have not seen anything mentioned about this even if it is still in beta with how much people have been wanting for something like it.
    Feb 2017
    TX
    761
    I messed with it for an hour a few weeks ago on cj/twin 67, just using the results from a few histograms.
    When you calculate, it automatically updates said tables without having to copy and paste.
    I think it will take more than a histogram to fill the cells for ETC properly. My results would have 0's in the first 5 or 6 columns, angled towards the last row.
    Drivability was not bad. I was getting a little oscillation at light throttle, full throttle has no problem.
    I want to mess with it some more. It's better than just changing predicted or making a guess.
    Nov 2007
    232
    I cannot wait to use this on a kenne bell 168mm throttle body I've been fighting with since July! All of the published approaches only get it so close. Thinking I may have something miscalculated somewhere. This should at least help. Way to go HPT!
    "I didn't fail, I just found 100 ways to do it wrong." - Benjamin Franklin
    Advanced Tuner bbrooks98's Avatar
    Oct 2011
    Gainesville, VA
    301
    Wasn't it concluded that getting a back calculated torque value from logged load would be an easier task that doesn't require a dyno? Hopefully that could be implemented too, but either way awesome to see these things added to the software!
    May 2016
    1,134
    Thanks for posting this. I have been tuning 2004 and older Mustangs mostly the last couple weeks and haven't even paid enough attention to realize this was there.
    Dec 2005
    222
    I think key is to have a little bit of a write-up on how they intend it to be used =>correctly<=. I believe Eric has said that this is coming.
    Jeff Chambers, Owner
    CRT Performance, LLC
    349 Cleveland Road
    Norwalk, OH 44857
    Ph: 419-668-4151
    Fx: 419-668-4643
    Performance Parts, Service and Dyno Tuning Specialists
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    Yeah we are prepping them now, I've already gotten to see most of the VE calc one
    May 2016
    1,134
    Awesome. This is really going to put you guys even further ahead of the competition.
    Sep 2010
    872
    The speed density one looks killer, can't wait to see a guide on how to use it, or if we can make histograms that can be imported into the calculator in order to populate them...
    May 2016
    1,134
    I have been tuning mostly EEC-V lately and it seems like getting the Load With Failed MAF correct makes a noticeable difference so I'm curious if getting this stuff right on the newer ECUs will have the same kind of impact.
    Oct 2011
    Gainesville, VA
    301
    Speed density calculator is very cool. Adjusting the axises into boost like the roush cals gives an idea of how it can be rescaled for a boosted car very easily.
    Tuning Addict
    Jan 2015
    6,804
    Finally... Thank You HPT...
    Will the VVE tool be getting added into all of the OSs including Roush, Whipple and so on?
    ~Greg Huggins~
    Oct 2007
    Crawfordville, FL
    2,412
    Speed Density calculator "should" work on all 2015+ vehicles currently, including those.
    The pre-2015 stuff is "slightly" different, and we will be updating the calculator to work on those vehicles in the next few days.
    Eric Brooks
    HP Tuners, LLC
    Advanced Tuner Witt's Avatar
    Aug 2006
    Pittsburgh, PA
    380
    Thanks for the update. I look forward to trying it on the Copperheads.
    Tuning Addict
    Jan 2015
    6,804
    It's not available as an option in the editor in all of them Eric... Here's one for example - whipple tune...
    AND thanks again - been waiting for this for a while now...
    ~Greg Huggins~
    Oct 2007
    Crawfordville, FL
    2,412
    Update again. It should be good now.
    Eric Brooks
    HP Tuners, LLC
    Tuning Addict
    Jan 2015
    6,804
    Thank You Eric... On a side note - any good read ups on a walk through on how to correctly fail the MAF and make corrections or do you even fail the MAF - also looks like an external map sensor is needed? Teaches me for not learning more on Fords early on :/
    ~Greg Huggins~
    Advanced Tuner 15PSI's Avatar
    Feb 2016
    East Coast Somewhere
    458
    I have the same question . BTW, Steven's write-up on the VE calculator is great reading, but honestly will take me a bit longer to understand the finer points. Will there be a similar how-to on the ETC Effective Area and Torque Inverse Calculators? I played with both yesterday, but am not sure I am starting from a position of knowledge LOL.
    2012 Mustang GT with S/C
    4Runner with S/C
    Turbo/NOS Hayabusa - 320RWHP
    Oct 2007
    Crawfordville, FL
    2,412
    You would tune the MAF cars like normal, and then populate the table with the correct load values. You would need a MAP sensor wired up.
    Eric Brooks
    HP Tuners, LLC
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by 15PSI View Post
    It's coming.
    Eric Brooks
    HP Tuners, LLC
