Results 1 to 6 of 6
Thread: Going into decel on cruise
    Hey guys. Have a 2007 LQ9 in a 73 volkswagen bus. Has LS3 injectors and Trick flow top end kit with fast manifold and BBK throttle body. Did the usual tune on it and drives fine except sometimes, not all the time you'll be holding a steady throttle in closed loop and all of a sudden goes to open loop decel and the thing goes lean and falls on its face. You continue to hold that throttle and it'll come out of it and go back in. It doesn't do it all the time. I've tried disabling DFCO and and left it stock with no success. I've logged pedal APP1 and 2 and throttle position and nothing changes when the issue happens. I don't see any change in MAP or MAF at the time too. No codes for anything.
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,460
    That sounds like a fun project. Did you change the injector data for the LS3 injectors in the tune? And are you using the O2 sensors?
    2013 Silverado 5.3, 6L80k 8.8
    Yes used LS3 data. Pretty straight forward tune. Using front o2s still.1973 Volkswagen bus with LQ9 built cam - GR.hpt
    13,565
    Does commanded AFR change too when it enters this decel?
    Jan 2006
    Naperville, IL
    94
    Just a wild ass guess, but does the VSS seem to be working properly?
    Rob
    2017 Chevrolet SS 6mt LSA
    Prior - 2015 Chevrolet SS 6MT LSA
    Old - 1998 BMW 540I Supercharged 402 LS2/T-56 swap
    Older - 1992 BMW 325i 402 LS2/T-56 swap
    Very old - 1995 BMW M3/ 402 LS2/T-56 swap
    Aug 2016
    Texas
    222
    Post pics of the bus!!
