Results 1 to 7 of 7
Thread: Enrich Desoot mode - what years is it available for?
    Sep 2007
    393
    I'm still using version 2.24 but have considered upgrading to version 3.6 for the Enrich Desoot mode functionality in hopes of eliminating some huge lean spikes when I launch the car at the track.
    I'm a little confused though as to whether it's available for my 2007 Corvette. I browsed several tunes in the repository (using version 3.6 on my work laptop) but didn't see it show up in anything for 2007 but did see it in some (but not all) of the 2008 ones I looked at so I'm not sure what's going on.
    Is it not available for 2007 or would I only see it in my tune after doing a read entire using 3.6?
    Thanks in advance,
    Christopher
    Tuning Addict
    Jan 2015
    6,833
    I know it's not available for all of them, because I have requested it on a few and was told it wasn't available - not sure if yours is one of those...
    If it's not available then you most likely have something else going on...
    ~Greg Huggins~
    Oct 2013
    550
    Looks like GM started using that programming (Enable vs Disable switch) beginning in the 2008 model year calibrations. Have never seen it in any of the early Gen 4 controllers.
    Jan 2014
    Australia
    1,988
    mine is 2007 and its not there but also not needed because no issue caused by it, i also have a 2008 ecu that it does have in it, looks to be early to late 08 might be the changing point
    Advanced Tuner veee8's Avatar
    Apr 2006
    Raleigh, NC
    449
    HP Tuners added it to all Gen IV ECM's that utilize it. If it's not in yours, GM didn't use it.
    www.crawford-racing.com
    Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
    Jun 2011
    Montreal, Canada
    758
    Not in my 07 vette either. Havent had a need for it luckily.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
    Advanced Tuner NJ_Phil's Avatar
    Jul 2016
    Flanders nj
    283
    Every desoot problem I've seen, including mine, has shown up 2.1 secs after entering PE. It might be something else if you're going lean at launch.
    A log showing WB and EQ command would help confirm it.
    2012 C6 Base, Kooks 1-7/8" LT, Catted, NPP
    Novi 1500SL, 10% OD IW, Big Blower Cam, Flip Drive, 2x Alky, ID1000
    Nitto NT05R 305x19, 255x18 on CCW T10s
    Self built and tuned https://www.youtube.com/watch?v=Kod2UTqrVwM
