Results 1 to 7 of 7
Thread: lq9 redline
    Oct 2017
    7
    lq9 redline
    Can't find anything on what the stock LQ9 engine can safely shift at for WOT rpms? Its a stock 06 sierra denali and where it shifts getting on the highway WOT going into 3rd gear its extremely doggy. 2nd - 3rd it shifts around 5100rpms and I see the engines peak HP is at 5200rpms. Just wondering how high i can safely shift at stock everything?
    13,574
    5700-5900 on stock valve springs to play it safe. I'm sure some have taken it higher but the horsepower has already fallen off before you ever reach 6,000rpm on a stock camshaft.
    I went from 5400-5500 in mine to 5700-5800 just fine.
    Oct 2017
    7
    if I am understanding hptuners there is no spot to pick for shifting RPM just in MPH shifting, correct? I have raised that 4-5 mph more in the 1-2 and 2-3 shift to see if that raises it to where I want
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    They can safely spin to 7,000, however what 5FDP told you is true. There is no point to rev it higher than 6000 because the stock cam and valvetrain will lose power above 6000.
    I have found that the sweet spot for the shift on those engines is: 5900 for 1-2 and 5800 for 2-3
    9 sec Montecarlo SS
    Oct 2017
    7
    sounds good to me.. better than 5100 - 5200 2-3 shift.. it feels so doggy. But where on HP Tuners can you shift by RPM? all I see is MPH shift
    Nov 2009
    Pegasus Galaxy
    919
    Next to the part throttle shift tables there are a few WOT RPM tables where you set the full throttle shift RPM. They only have one value per shift, easy to recognize
    9 sec Montecarlo SS
    Oct 2017
    7
    thank you I will take a look at it!
