Hello,
As the weather is colder, I noticed the rough sound from exhaust , then I checked the spark timing showing -3~-2* degree.
On the log of a day before the above, it showed 14~16* degree.
After searching the site, there was the similar question.
At idle, minus, but going back to normal as the car moving. The post said the ECU is trying to get RPM down with minus timing due to many reasons like air leak.
I checked any leak on the system, but seems not.
I am wondering what affects to the idle spark timing? I understand just after start, it pushed the timing to get the temp up.
However, after long driving, it still shows minus timing. Is it bad?
Nothing wrong, except the sound. If I accel, everything is working good.
Thank you,
