DSC Disable / Delete (Stability Control) on FG UTE after 6 speed auto conversion
I have a 2009 XT Falcon Ute which had a 5 speed auto. I fitted running gear from smashed 2010 XR6 Ute including 6 speed auto/ ecu/pcm / ABS unit /etc. The 2009 XT ute did not have DSC, and no easy option to retrofit as there is no harness for Steering Angle Sensor etc. How do I disable the DSC in the XR6 Ecu. I have also tried a full reflash with software from a 2011 XT Ute which has factory 6 speed, and no DSC, but still getting the DSC error. If I physically fit the 2011 XT Non DSC ecu + matching security kit the error goes away. Does the HPtuner software not actually do a "full erase" and rewrite? I did consider it needed to be disabled in the ABS unit but that does not seem to be the case as the ECU/PCM swap cleared the error. Thanks in advance for any suggestions
