Results 1 to 9 of 9
Thread: Rev Limiter switch to Spark cut?
    How can I get the rev limiter to use spark cut instead of ETC or Fuel? Messed with the spark ratio and fuel cut ratio some and no luck. Set N rpm limit time 4k hits it and uses furk cut
    Go to spark limit rpm x load . Change the last row to your expected limit rpm . Change the column to -20
    Can't seem to find that table
    Like cylinder pressure limit table?
    Most Ford ECUs I've seen do not support just cutting ignition.
    The only time I see them actually cut ignition is when they've cut fuel.
    By default the ECU doesn't support this operation essentially.
    Yes cylinder pressure limit is a spark control . Mine is up to 8000 and then 8001 is -20Attachment 74900
    Attachment 74901works fine for me
    That is not an ignition cut. That is just massive spark retard. Its still firing the spark.
    Jan 2013
    Hawaii
    2,101
    I read something about setting torque hst. To 0 under the fuel cut section and it gives a fuel cut instead of a throttle closure. I never have gotten around to seeing what exactly it does.
