Results 1 to 15 of 15
Thread: Logging MFDES 6.0 Powersroke
    Jul 2015
    Florida
    28
    Has anyone Logged MFDES (mass fuel desired) during a WOT run to see if it is actually going over 100.....I have logged over and over and changed everything I can think of in the tune to make sure my fueling isn't limited to 100. no matter what I do as soon as I go wot it caps at 100 everytime . I have looked at a couple of other tunes in the repository and mine and their fueling are commanded over 100 MFDES
    thank you in advance and if you would.... post up some datalogs that confirm going over 100
    I have attached a datalog to show what I am talking about
    Advanced Tuner RandomEnthusiast's Avatar
    Feb 2016
    Texas
    333
    Quick way to confirm. Is load your table with 100 max all across the top end then load it max and see if there is any difference. Trust me there should be.
    Did a pull today, hits a hard limiter at 100. Attached log and tune.
    WOT.hpl
    V2.hpt
    Jul 2015
    Florida
    28
    Yea we are working on this....no matter what you put any limiter.... it will cap at 100... we should see at least up to 150...the stock injectors most likely wont handle any higher than that
    Feb 2016
    Texas
    333
    Odd that it maxes at 100. To get around this I would flash the ficm or modify the hpop tables to max pressure at wot.
    Jul 2015
    Florida
    28
    I just think its a processing issue with the factory pcm.... the stock injectors will only flow 108 MFDES anyway.... I am not sure on volume..im sure you would feel it cap with that... I monitor smoke and egt for my fueling.... I see more changes there over the 100MFDES cap
    Tuner qwkvert's Avatar
    Nov 2014
    Melbourne, FL
    61
    Attachment 76049
    Attachment 76050
    Attachment 76051
    heres 2 logs, and my tune. Maxed out at 100mg it appears?
    Nov 2014
    Melbourne, FL
    61
    I need more of those horse powers!!!!! Lol...
    Feb 2016
    Texas
    333
    Spoof the icp voltage.
    Nov 2014
    Melbourne, FL
    61
    Could you elaborate for me? I'm a rookie on diesel.
    Feb 2016
    Texas
    333
    Crap it didn't post my picture. Under fuel system on the top bar. Sensor pressure vs voltage and voltage vs pressure. Lower the voltage for max icp pressure to something like 3.5 and the ficm will add pulsewidth.
    Nov 2014
    Melbourne, FL
    61
    Not sure that would help since I upped the pw in the ficm already?
    Feb 2016
    Texas
    333
    You might be out of injector. But it should boost to over 25 easy.
    Nov 2014
    Melbourne, FL
    61
    That's what I thought. I wonder what role timing plays in it? In running 9* max right now, not sure if I should push it to 12 or not.
    Feb 2016
    Texas
    333
    Well I topped out at 28psi on fuel only with 10 degrees so it's fuel limited somewhere.
    Or you've got a boost leak. I'm going with boost leak.
