2006 GMC 3500 cab and chassis 6.6 stock tune. Getting P0606 codes. from what i can see it needs an GM updated flash. Is that something i could get out of the tune repository? if so how could i find it to know that it is the updated flash??
Good luck getting a response in here. It's a dead forum...........
Normally a P0606 is a PCM failure code. But it seems to be a incomplete programming routine for the diesel pcm.
Are you able to re-flash the pcm back to stock with a Tech2?
98 TransAm WS9 Raim Air – Stage 4 4L60E Trans -3:90 Rear -1.8 HS Rockers - Full UMI Suspension – 85MM Lid – 85MM Z06 MAF - LS6 Z06 Intake - 224/230 Comp Cam - 7.350 Push Rods - 243 TEA Stage 2 LS6 Heads 61cc - Melling 10296 Oil Pump - Caddy Race Lifters - SLP Underdrive Pulley - 160 Thermo - 42# Green Top Injectors - HPT - SLP Line lock - Pacesetter LTube Headers - Yank SS4000 - 98 to 2002 PCM Swap www.mrk-motorsports.com
