Hey I have a TBSS that I'm spraying. Logged it tonight while spraying and noticed it didn't pull any timing. I am using the IAT relay trick to fool the ecm to pull timing.
I have a resistor inline that jumps the IAT to 12* when triggered. Well my table doesn't have a 12* range. Only 5 and 14*. Well I figured 14* was close enough for it to work correctly. but its not pulling any timing. I do have the multiplier to 1, with -8 for the timing pulled.
My question is should I have the same exact temp and columns for It to work correctly? I figured the ecm would use the closest cells.
I'm thinking of removing resistor and just using the relay to ground the IAT and make it read -40 completely.
Thoughts?
