Originally Posted by
kris5597
Hey guys,
All of the ecoboost cars I have tuned are defaulted or at least have the option to change the knock mode from global to per cylinder. An update not to long ago now gives me this option to do on the coyote engines as well. Like the ecoboosts, the 2015+ 5.0 cars allow for the knock sensors to monitor individual knock per cylinder, which in return, with the knock mode set to per cylinder, allows you to see what each is doing separately rather than one detecting knock and all cylinders get timing pulled from it. I don't have a whole lot of experience doing that on the 5.0 cars but every ecoboosts I do. The reason for not much experience on the coyote cars is because I have never had an issue hitting the targeted timing with the global set... until now.
I recently finalized the calibration on a customers car, this is a 2013 GT with intake, catless header, exhaust, 93 octane car. I have checked everything I can think of but this car always had issues hitting target timing, kept wanting to pull timing, more than I have seen, especially with the setup. To the sum of 21-22 degrees at peak torque and the max of 24-26 degrees at peak power. I figured I would give the knock mode a change to per cylinder to see if this would help. All of a sudden the car woke up and hitting target timing and would advance up to 31 degrees of timing. The biggest concern is you cannot log knock per cylinder on the 11-14 cars and I was receiving no feedback from the knock sensor with adding or subtracting timing. With the fear that this somehow disabled the knock sensor and also not being able to monitor the car, I changed it back to global adjustment on the knock sensor and it went back to the same timing curve as well as feedback from the knock sensor with adding and subtracting timing.
Does anyone have anything to chime in with on knock per cylinder on the 11-17 5.0 powered cars as well as the missing date from the 11-14 for knock per cylinder and not being able to monitor?
Kris
