Results 1 to 2 of 2
Thread: VCM Scanner Question for Dodge Platform
    Nov 2017
    4
    need some help with a couple DTC,s I am getting. I want to turn them off. I can locate the Coolant code but not the others. See image for the codes.
    I have a 180 Thermostat installed which should be the reason for that. The other 2 are my Active Exhaust Valve actuators which are unplugged due to aftermarket exhaust.
    Can someone help identify why I can not find these codes when I check in the Engine Diag. Thanks in advance for the help.
    Following
