I downloaded my factory tune this evening and started working (slowly) through it. I would like to disable Tq. Management, so I hit the "RPM vs. Gear" table first. It has already been populated with "6042." Is this a common occurrence? After some searching here, I also disabled "ETC limit" under "Tip-In Limiting" (Torque limit was already disabled). Do I also need to disable "Use Fuel Cut" and "Use Spark" under Fast Torque Exit? What should I change under the Transmission part of Torque Management?
