Results 1 to 5 of 5
Thread: IFR multiplier p12 5 cyl question
    Aug 2016
    25
    I want to run 80lb injectors on the colorado/canyon p12 pcm. Does the ifr vs volts multiplier table work? Ie divide IFR by 2 then enter 2 in the multiplier table.
    Sep 2017
    Coatesville
    8
    Quote Originally Posted by ah206 View Post
    im still pretty new to this but hopefully someone will correct me if I'm wrong. If your dividing the flow rate in half then your essentially entering 50% of the actual flow rate so in the multiplier your entering 1.5 to add the 50% back in, thats what i did with my p12 computer in my cobalt also with 80# injectors as well, although I'm still working out the bugs to get it near perfect its idling smoothly
    Dec 2008
    Nevada
    4,452
    If you divide by two then your multiple is 2 not 1.5. (80/2)*2=80. (80/2)*1.5=60
    Aug 2016
    25
    Yep half IFR and multiplier set to 2. It works just fine. Went with the 72lb ev14 injectors.
    Dec 2008
    Nevada
    4,452
    Nice!
