I don't have a lot of experience with Dodge tuning when it comes to automatic transmissions. Could someone take a look at the attached ROM and look at the trans tuning and let me know if you see something odd? The car in question is a 2010 Challenger with a roots supercharger, 2 bar map sensor, and 60lb fuel injectors. AFR and ignition timing are fine. I tuned the car on the dyno and then worked on the trans line pressure on the street.
The transmission tuning is what I am curious about. I modified line pressure for the increased load from the supercharger. On the stock trans mapping it drove really bad, i.e. hesitation etc. I am wondering if the trans is hurt or is it just the map? A dealer bought the car from an auction and it already had a blown up motor prior to bringing the car for the tune. They swapped the motor but not the transmission to get it ready for resale. They brought the car back so I could take a look at it once again. Car definietly has hesitation and other strange characteristics.
Thanks for your ideas.
