questions on the pe hot pedal and map pe
the hot pedal pe vs throttle postion ,, how accurate is the percentage verses the actual throttle postion? ,, at idle its already @ 20% ?
in the PE enrichment section It shows several tables on PE criteria,,need an description on what those tables relate to
for instance as I just ease in to the throttle I want the PE table to pick up the desired afr , I need to be @ 60% to get it to kick in and will go to the extreme on the afr command ,, do I need to richen up the maf so the afr is ahead of the pcm calculation?
this is just part throttle and just working on getting the lean area out of the tune
wot is working well ,commanded is real close to actual just looking to fine tune the 25%-45% part throttle performance
not clear on the map PE table enable on how it is calculated ,hysteria calculation also
5% fuel increase 3300hz-8900hz.hpl
gmondeperformance 2009 g8gt lsa fine tune transmision shift points engine knock retard.hpt
how many tables affect the pe enable ?
thanks in advance gmonde
