I had a 2016 Chalenger SRT8 6.4 w/auto trans on the dyno yesterday and I noticed that making changes to any/all of the exhaust cam phasing tables made no changes to the actual cam position. Logged cam position did not change nor did power output with changes to the exhaust cam tables. I also noticed that the logged cam position did not match the WOT cam tables at all. It actually exactly matches the Warm up table (and also if you merge the high load areas of the Lo and Hi Baro Cam Maps, it matches those as well). Has anyone had success moving the stock cam on these? This is with vcm 3.7 btw.
