Results 21 to 40 of 55
Thread: OEM Camaro LT1 8speed A/T throttle response in 3rd
    Sep 2011
    Germany
    196
    Quote Originally Posted by IARLLC View Post
    ZR1 Driver, You mentioned above, "i have done a System segment swap on a 2017 Camaro EU from ID 12678404 to ID 12678400 (US)." Did you use acdelco TDS? Years ago they were much more cooperative on such things. With a phone call I used to get them to give me other options. The last few years they have become pretty rigid about what they allow.
    no you can do this with HP Tuners.
    Aug 2016
    942
    Thank you, ZR1DRIVER. I understand now. I thought since you mentioned the chassis module that you knew a person at ACDelcoTDS that was nice. I am dieing to get better access to GEN4 and GEN5 BCMs.
    Sep 2011
    Germany
    196
    Quote Originally Posted by dertobi View Post
    It has nothing to do with the torque model itself.
    Zr1 driver and I are in contact, and he will test my solution next week, because I dont have a car available that quick.
    Meanwhile I am 100% sure it is the map I mentioned above, which is not in hpt
    It is a axle torque limitation. Also we found out that this limitation is not as bad on the '16 models then on the '18.
    here a small update after talking to dertobi. i was able to create a .xdf from the hex address where we are suspecting the torque reduction and put the definition in hp tuners.
    the next days i will run some tests on the dyno but i?m sure we are on the right track.
    Apr 2013
    210
    wow thats awesome. How did you end up doing that? and where did you get the access to this? Im guessing winols was used or something to explore the rom. Is that what the custom parameter option HPtuners offers??? Best of luck in finding the issue
    ZR1driver gave the hint that it must be in the system calibration...i fired up my Winols and found that pretty quick
    I knew it must be in the ECM but I didn't know where to start searching, there are pretty much differences from US to EU model when you look at it in OLS
  6. #26
    Apr 2013
    210
    im too poor for winols lol good stuff.. maybe protuner RT could have worked too?
  7. #27
    Sep 2017
    5
    Quote Originally Posted by zr1driver View Post
    Im confused..can we see the setting in HP Tuners or just in Winols ?
  8. #28
    Sep 2011
    Germany
    196
    HP Tuners dont support this table. you need to know the adress in Hex and do the definition by yourself with user defined parameters.
    i still have to check if it work but i'm sure it will.
  9. #29
    Aug 2016
    942
    Wow! Thankful for your research and input! And anybody stuck with that torque table should be even more thankful for a revision.
  10. #30
    Sep 2011
    Germany
    196
    its working. torque reduction in 3. gear is gone :-)
    mod
    stock
  11. #31
    bzzzzz...let's keep it our secret
  12. #32
    Sep 2011
    Germany
    196
  13. #33
    Mar 2010
    Texas Hill Country
    3,299
    well done guys!
  14. #34
    May 2003
    South FL
    1,359
    If you send the definition to HP Tuners they will usually add it to the Beta version.
    [email protected]
    Owner/GM Calibrator
  15. #35
    May 2018
    Germany
    569
    Hey Guys,
    what hardware do I need to write the corrections to the car? UCM BDM ??
  16. #36
    Mar 2010
    Texas Hill Country
    3,299
    Quote Originally Posted by f.creek-ranch View Post
    Hey Guys,
    https://www.hptuners.com/mpvi2/
  17. #37
    May 2018
    Germany
    569
    Quote Originally Posted by Higgs Boson View Post
    Not for corrections in the System. The GUI from HP don't show the hex file to edit the torque reduction that needs to eliminate.
    Winols seems not to use obd2...
  18. #38
    Mar 2010
    Texas Hill Country
    3,299
    HPT Editor - Edit - User Defined Parameters
    https://forum.hptuners.com/showthrea...ned-Parameters
  19. #39
    Apr 2019
    Hi to all,
    I'm an owner of MY18 European Camaro 6.2 AT8... and I've the same issue.
    I've HP Tuners
    Could be great if someone share solution to this issue
    Kindly Regards
  20. #40
    Sep 2017
    5
    Is it possible that you could you pass the info to HP-Tuner support so they could add this parameter to VCM Editor ?
